Hi, the mosfet source is at 12 volts dc. This is what I find confusing. Does the mosfet Vgs consider 12 volts as ground. If this true than the gate needs 10 v plus 12 volts to turn on with respect ground? The nand gate oscillator and voltage multiplier does produce 24 volts, so I am searching for a circuit that will oscillate from 12 to 22 volts so the mosfet will turn on and off.
