Good morning to all:
I was troubled by a problem,
if i have a 40 KVA load, upon application to a 115V 400hz power supply
is there anyway i could calculate the drop of voltage upon application of the load or the "surge" in voltage upon removal of load.
And is there a possibility to also find out the duration for the voltage to be stabilize after the removal or application of load ?
