Hi to all.
Im new to this forum and new to electronic. I need some guidance. Currently im doing a project for my final year. My project have two infrared sensor which i put at entrance and exit. I mean like visitor counter. I use atmel 8052 microcontroller (AT89S52) and i program it in assembly. I program port 2 as sensor input,port 1 is output and port 3 as counter which give 8 bit binary code from P3.0 to P3.7. Im stuck with the counter part only. The others all ok. I want to display from 00 to 99. So,the 8 bit binary will display until 99. I already done with two common anode 7 segment display and two SN74LS47N ic which is BCD to 7 segment decoder. The display will display from 0 to F. In BCD,it just display 0 to 9 right? how do i skip from A to F? I mean,i just want to display 0 to 9 only. I also try using common cathode 7 segment with 74HC4511.The ic is the same with 74LS47. The result is the same. But when the counter reach 10 to 15. It will give blank display for A,B,C,D,E,F and come back to 0. so it will count until 15 too. Suppose after 9 it will display 0 and another one 7 segment will display 1. it will display 10 by using two 7 segment and it will count until 99. Can anyone please help me.. how do i skip A(1010),B (1011),C (1100),D (1101),E (1110), F (1111) and just displaying 0 to 9. Another things is do i need binary to BCD converter ic for displaying 00 to 99? Sorry for my bad english.
