So it's been a while since I've become a hobbyist when it comes to retrogaming. One of the things that I've been doing successfully is RGB modding CRT TVs. But since not everything are flowers, there are things that will always pop in to generate doubt, one of these things is this: identifying analog and digital video signals on ICs.
I've come accross this awesome 14" Panasonic TV set:
![20240618_113234.jpg 20240618_113234.jpg](https://forum.allaboutcircuits.com/data/attachments/312/312526-9c0cbaaee7f9aaee822465d903369006.jpg)
And now I don't want to lose it, but firstly I need to know if its microcontroller has analog RGB. Checked the service manual, it is said that the microcontroller has RGB / YUV (pins 46, 47 and 48), as you guys can see in the image, so I've decided to check the datasheet to see if it is digital or analog rgn and it only made things worse... Well, look at this:
"Linear RGB or YUV input with fast blanking for external RGB/YUV sources. The Text/OSD signals are internally supplied from the µ-Controller/Teletext decoder"
![Screenshot_20240617-092338_ReadEra.jpg Screenshot_20240617-092338_ReadEra.jpg](https://forum.allaboutcircuits.com/data/attachments/312/312524-e5bcbf772cf7d5f47dd0190ee0d33320.jpg)
![Screenshot_20240617-092210_Drive.jpg Screenshot_20240617-092210_Drive.jpg](https://forum.allaboutcircuits.com/data/attachments/312/312525-d4fd43fc0051e99ed0764d1f8c01d43b.jpg)
This is from the datasheet:
https://pdf1.alldatasheet.com/datasheet-pdf/download/1315009/PHILIPS/TDA9381PS/N2.html
The Tv service manual:
https://elektrotanya.com/panasonic_tc14a12_tc20a12_chassis_br3l_sch.pdf/download.html
So can I use analog rgb on those pins or...?
Also, how can I identify digital inputs on these ICs, only if they have y pb pr written in the diagram?
And what is linear RGB in this context?
Please answer all the three questions, I need to know this information.
