Thanks everyone for the help...I feel more confident with my idea...I really appreciate everyone's time....
aww sorry big guy; if it helps, I made myself an example of what not to do after you did so that make me the bigger dummy.I've been reading along and staying quiet, not wanting to interrupt, but I get dragged into the chicken coup anyway...
AND i'm used as an example of what NOT to do. Thanks fellas.
I like your design. thanks for posting pics; not everyone does thatHere are some pictures of what I'm working with....
No problem. Come back and let us know how it works out and we'll see about the next phase.Thanks everyone for the help...I feel more confident with my idea...I really appreciate everyone's time....
I don't see a problem with this.So is it OK to run the DPDT off the same power I'm running my motor off of.
Yes, you are being paranoid.Also would it be a good idea to set up a limit switch on the same timer, that would set off an alarm if the door didn't close. Lets say I have the door closing when the timer is on, and the DPDT stops working or fuse blows. Then when the timer went off if the alarm limit switch isn't released, then it would go off. Or am I just being paranoid and over thinking again. I guess this would be an audio notice every time the door closed, because it would be activated until the door closed enough to release it..... Just use the same timer, one limit switch normally open (mounted at the fully open position.) and then something like a dc horn or siren.
If you need to be sure that the door has really closed you take a DC-buzzer, take a diode with the proper current rating, connect the cathode of the diode to "+" of the buzzer. Mount the buzzer/diode in parallel with the motor in the direction that it will sound when the motor turns to close the door. As soon as the motor starts closing the door the buzzer will sound and when the door hits the end switch, the buzzer turns off.I was thinking that when the timer powered on the alarm would sound until the door released the limit switch. If the door didn't move then the alarm would stay on.
Actually the way you are doing it now, is the best way for now, since you don't have the experience yet to do bigger things.praondevou
If you have the time and patience. Do you mind laying out your suggested system using a PLC or MCU set up...I'm just intimidated by my ignorance of them.....thanks
I defiantly see a start and end to this step of the project. All components are on order. I'll post pictures of completed project.Actually the way you are doing it now, is the best way for now, since you don't have the experience yet to do bigger things.
This looks like something I can play with later after I'm done with the door project. Thanks for the info.If you need to be sure that the door has really closed you take a DC-buzzer, take a diode with the proper current rating, connect the cathode of the diode to "+" of the buzzer. Mount the buzzer/diode in parallel with the motor in the direction that it will sound when the motor turns to close the door. As soon as the motor starts closing the door the buzzer will sound and when the door hits the end switch, the buzzer turns off.
by Duane Benson
by Aaron Carman
by Aaron Carman
by Jake Hertz
