This is a piece of cake and a lot of fun for someone with MCU programming knowledge.
IR LED emitter and sensor aligned below and above the track is the way to go.
One MCU board can time both tracks or you can go with individual boards.
You can go with a manually operated start switch. You can also consider individual optical triggers for each track which would eliminate false or slow starts (depending the your preference and rules of the game).
I can even program two MCU chips for you or you can have a go at it with our guidance. All up to you.
