Pin Function of LT4363
hassej
Joined Dec 12, 2022
8
Hi everyone, I would like to know your insights about the functions of SHDN, ENOUT and FLT pin in LT4363 this is a surge protection IC. I copies the circuit in the typical application since I am also using a 28V input.
I should let this float or maybe connect it to somewhere or maybe mark as unconnected??
Send help.
Thank you!
ericgibbs
Joined Jan 29, 2010
18,848
My reference with this is a MPS ic which they uses MOSFET transistor. BTW, this is LTM8053/LTM8053-1 a step-down module regulator.
hi,
I have downloaded the LTM8053 d/s.
Do you have a circuit diagram showing how what you have connected to the MPS to the PG output pin.?
E
hassej
Joined Dec 12, 2022
8
actually this is not my circuit this is only my reference sir, and the IC that they are using her is from MPS while I am planning to use IC from ADI, and in the MPS they already stated in their datasheets on how to use the PGOOD pin.
ericgibbs
Joined Jan 29, 2010
18,848
hi hass,
I don't want to guess, when will you have your final circuit to post, so that I can give you a meaningful answer.?
E
ericgibbs
Joined Jan 29, 2010
18,848
hi hass,
I will look over the usage of PGOOD, but I would like to see your idea's on how it may be used.
Is this a College assignment?
E
