The programming pins on 18 pin chips are in different places to 20 pin chips so you can't just plug it into the socket.It is an 628a i guess. SO it will work ok even if the holde has 20 pins? Still not sure about programming it though.
I plugged it in the forward position with the last 2 pins empty.
I did not say a PICKIT 3 would not work. But you have confirmed that you use 16f628A. And both PICKIT 2 and 3 support this device from MPLAB. If you put a 16f628A in the socket of the board mentioned before. You will get the exact same error.Excuse my ignorance but why would a pickit3 not work. The site said to use a pickit3 so I was assuming it would work.
Oh what a difference an "A" makes.It is an 628a i guess. SO it will work ok even if the holde has 20 pins? Still not sure about programming it though.
If you have the extra money than go for it but I would not toss that PicKit 2 just yet. It has a lot of features not found in the 3.Maybe I should bite the bullet and buy a pickit3.
P | PICKIT2 prolem | Microcontrollers | 8 | |
P | PICKIT2 and PICKIT3 doesn't wotk on My WIN10, but they work in XP, which is not connected ro Internet | Microcontrollers | 10 | |
P | PICKIT2 problem "Verification Fail" | Microcontrollers | 11 | |
Re tuning the Pickit2 | Microcontrollers | 23 | ||
Pickit2 Not detecting | Programming & Languages | 5 |
by Don Wilcher
