Do you have power to the device?I can't get it to work. It says no device found.
See my post above.Ok, I got to detect. WHen i try to program it says "programming failed at program memory adress 0x00000"
If you use the standalone program that the pickit2 ships with, you can flash the pic that way. 16f628 should be auto-detected under 'midrange-->standard' in that small app.Yes. mplab. SO does that mean i need a pickit3 then?
I have a 16F627 hooked up to the PICKIT2 on the mid-range - standard auto-detect setting; just read the memory. See picture below for pinout (datasheet wasn't much help for me). 16F627/8 share a datasheet, FYI.Yes according to what I am seeing.
Or get a Pic that is supported by the PicKit II.
Strange page 121 of the datasheet does not list the PicKit 3 either only
Device Programmers
- PRO MATE® II Universal Device Programmer
- PICSTART® Plus Development Programmer
The datasheet misled me. Usually, you see pins labeled "PGMD" and PGMC" or something along those lines. All I saw was "PGM" on pin 10. I actually goog'd it and found an image of someone else's breadboard to learn how to hook it up. After that, the standalone app was happy.I think the OP was trying to program with MPLab. Good to see that it works with stand alone programmer as you say. Strange it is not listed on the chips datahseet.
OH! That explains it.Ok so I can't use the board that comes with teh programmer. I plug it onto my breadboard and hook it up that way, eh?
P | PICKIT2 prolem | Microcontrollers | 8 | |
P | PICKIT2 and PICKIT3 doesn't wotk on My WIN10, but they work in XP, which is not connected ro Internet | Microcontrollers | 10 | |
P | PICKIT2 problem "Verification Fail" | Microcontrollers | 11 | |
Re tuning the Pickit2 | Microcontrollers | 23 | ||
Pickit2 Not detecting | Programming & Languages | 5 |
