I am making progress using an external 32Khz crystal to count number of seconds. It appears to work but the timing is well off.
Please see code:
Have I calculated something wrong? As I am using a prescale of 1:1 according to the data sheet the WDT must be enabled, should this be set up in the config files first? Thanks
in fact when setting the prescaler to WDT to get a prescale of 1:1 the value of days is never incremented.
Please see code:
Rich (BB code):
/** C O N F I G U R A T I O N B I T S ******************************/
#pragma config FOSC = LP, FCMEN = OFF, IESO = OFF
#pragma config PWRT = OFF, BOREN = SBORDIS, BORV = 30
#pragma config WDTEN = OFF, WDTPS = 32768
#pragma config MCLRE = OFF, LPT1OSC = OFF, PBADEN = ON, CCP2MX = PORTC
#pragma config STVREN = ON, LVP = OFF, XINST = OFF
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF
#pragma config CPB = OFF, CPD = OFF
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF
#pragma config EBTRB = OFF
/** I N C L U D E S **************************************************/
#include "p18f45k20.h"
#include "delay.h"
#include "delays.h"
#include "switch header.h"
/** D E C L A R A T I O N S ******************************************/
void main (void)
int Day =0; // number of days
int Counter =0; // counter
int Sec = 0; // seconds passed
PORTA = 0x03; //Preset RA1,RA0 to 1
TRISA = 0x00;
INTCON2bits.RBPU = 0; // enable PORTB internal pullups
WPUBbits.WPUB0 = 1; // enable pull up on RB0
ANSELH = 0x00; // AN8-12 are digital inputs (AN12 on RB0)
TRISBbits.TRISB0 = 1; // PORTB bit 0 (connected to switch) is input (1)
// Init Timer
INTCONbits.TMR0IF = 0; // clear roll-over interrupt flag
T0CONbits.T08BIT = 0; // 16bit operation - reduces the need to use prescale 16
T0CONbits.PSA = 1; // WDT enabled prescale 1:1
TMR0H = 0xE0; // clear timer - always write upper byte first
TMR0L = 0xBF;
T0CONbits.TMR0ON = 1; // start timer
/*Fosc = 32KHz
Fcycle = Fosc/4 = 32KHz/4 = 8KHz
Tcycle = 1/Fcycle = 125us
Cycle count (no prescaler) for one second = 1s/125us = 8000
16bit overflow value = 0xFFFF (65535 in dec)
Calculate TMR0 (H&L) values:
65535-8000 = 57535 (0xE0BF)
while (1)
if(INTCONbits.TMR0IF) // when overflow occurs increment sec integer
Sec ++;
if (Sec==10) // 10 seconds represent one day for now
Day ++; // in debug mode I am running cursor here it takes ages to return a value of one for days?
Sec = 0;
