By adjusting the potentiometer I can do get a 3.25 to 4.5v volt different in dark and light.
I do have a LED that I wanted to use to test the circuit... right now the LED is plugged at the pin 4 of the UA123 and ground... Is that sounds correct?
The measure at pin 1 are very variable (very sensitive to light) I did a careful test and the value are changing from 4.8v with intense light to -4v in ~ total darkness.
Sorry for the confusion... this is my first electronic experience.
Take te 1 K resistor from pin 10 and put it to pin 12 to trigger the 123.
Did you put a current limiting resistor in series with the led on pin 4 of the 123.
I should take a 470 Ohm resistor.
I can't see the schematic because it was made too small and was saved as a very fuzzy JPG file type instead of as a very clear GIF or PNG file type.
If the ICs are old fashioned TTL then you need to know their spec's:
1) Input low voltage is 0.8V or less. 0.4V allows for some noise immunity.
2) Input low current is a max of 1.6mA. Therefore for an input to be pulled down to 0.4V with a resistor then the resistor must be 0.4V/1.6mA= 250 ohms or less. A few ICs have less input current so might work with a higher value.
So the photo-transistor (or is it a photo-diode?) would be working very hard to create a logic high because the minimum logic high voltage is 2.0V, or 2.5V with some noise immunity. The 250 ohm pull-down resistor needs 2.5V/250= 10mA. The photo-transistor must conduct 8.4mA which is a lot of current for a photo-transistor.
Instead, if the photo-transistor is connected to ground to pull the input to a logic low then its current is only 1.6ma plus a little for a pull-up resistor.
The rest on the 123 is connected correctly.
Pin 14 and 15 are for the timing circuit.
Pin 16 is the + 5 Volt.
Pin 8 is for ground.
The resistor to +5 volt on the 123 is to high, maximum usable is 180 K, see datasheet.
The value of the resistor may be between 5 K and 180 K, depending on the time of the output pulse.
In the datasheet there are formulas to calculate the pulse time.
Greetings,
Bertus
PS at the moment it is 9 o'clock in the evening over here. (Amsterdam, Holland).
ok Thanks I'll use a 150k first.
One last thing for tonight... where should I connect the LED to test the circuit..
such that the LED will flash for each pulse..
Bertus.... you are a GENIUS..... The circuit looks great.
I'll have to test it later with an oscilo //to test the duration of the pulse
and see whether or not I can detect the TTL.... any suggestion for that purpose ?//
I would need a brief TTL of 5v.
Then, I'll make a copy of the final diagram and picture of the circuit.. to put it on the forum...
We really want to thank you for your patience and kindness,
