Photo Cell Sensor
nubbins
Joined Nov 22, 2013
3
I have a 12vdc photo cell sensor, when triggered a 3.3v is on the output.
How can I get a 12vdc out when the sensor is triggered?
17,498
You could use an external transistor. What's the voltage at the output when not triggered?
Also, please provide details of your sensor. It could be an open collector output.
#12
The instructions say it outputs 3.3 volts.
This circuit will convert that to "0 volts to 12 volts" with a current capability of 50 milliamps. You can change the resistor values to get different amounts of current. You can add another transistor to get the voltages to be "12 volts to 0 volts".
#12
What else would it represent? Some other transistor that I imagined connected to a sensor you are not talking about?
