See the National Semiconductor datasheet for the LM117/LM317, top left on page 9. Explanations are at the bottom of page 8 and top of page 9.It is based on a design I found elsewhere. I think it say it was for short protection or some such thing. But doesn't the LM317 already have that?
I will make the change at your recommendation.
They are only 10uf caps. Would they store that much of a charge?
They will eventually drain via the constant load of the regulators. Keep in mind that each regulator represents at least a 5mA load on the filter cap, depending on your "R1" values. The 7805 is approximately 5mA.What drains the larger filter caps? That always seemed to be the bigger issue with this supply. The original designer suggested a permenent load.
I think we've been over this before.
Yes.I will go ahead and add the center tap back in. One diode rectifier, just like before?
