Not that lot's..... It's just a sign..lot's mean it will need big cladsDo you have gerbers of your design?
I've got excellent PCB houses in the states (US) and a few China sources too.
Define "lots"
China min is like 3,000 boards depending on size.
My kinda guy....but this needs to be professional and I have to give 1 year warranty. So I need this to be faultless.Here's a crazy idea that might work. 0805 and 1206 sized SMD LEDs will fit on stripboard, which will be a lot cheaper than etching.
Each letter is around the size of ur palm. I said that, before, somewhere...what quantities and what size is each PCB?? Have you checked out places such as ExpressPCB, etc.
Yup !!Just to clarify:
You need 8 boards, shaped into letters?
It would be easier for me to say:"Yes, I can help you." Or "No, I can't help you", if I saw the board layout and the dimensions.
OK, I got the mail.Check mail...subject..here it is
If you can get the PCB let me know. We'll talk about the layout and the size and all..
The letters are made from acrylic. Box type letters. Hollow inside.
PCB needs to be inside the letter..
Only needs to mount SMD Led's in groups of 3 through out the letter's, with resistors too...
after that it will be covered in clear epoxy to weather proof.. So I guess just copper traces will be there.
I will draw the layout if ur price is not up to my neck.
see the logo....the white "W" will be lit ...not the red part.
I got this policy: No cure, no pay.I will draw the layout if ur price is not up to my neck.
