Output of function generator is clamped positive
fender7802
Joined Apr 7, 2012
43
I'm using the Elenco FG-500 function generator kit, and when looking at the output on a scope, the sine wave is clearly sitting about 3V above ground. When the output is taken with a DC voltmeter, I get about that. Anyone have any thoughts about this?
The schematic is on page 3 of this PDF:
http://www.tequipment.net/pdf/Elenco/fg-500.pdf
My thoughts were that there must be some unwanted capacitance in the output circuit, and it was the case that C7 was backwards, but after switching it I still have the same problem.
Thanks
DickCappels
Joined Aug 21, 2008
10,179
The output is above ground because that's how the function generator works. The negative power supply of the chip and all outputs will be above ground. One "fix" would be to float your circuit's ground at -3 volts. Another way would to be capacitively couple the signal from pin 2 to a grounded resistor (220 uf and a 10 k resistor should be pretty good down to 1 Hz. Connect the positive side of the capacitor to pin2 of the IC and put a 100 ohm resistor in series with the output of the circuit or much better yet, add a buffer.
