What kind(s) of transistors are you using in your sim?Running this as class A is really inefficient but this is what I roughed out. The output is just starting to clip at the input level shown.
Been a long long time since I've played with resonant and cascode amplifiers. In fact, the last one I built for 20 meters was a cascode preamp using two 6CW4 miniature vacuum tubes. I still have it 35 plus years. They were just a bit larger than a T05 transistor.Me again..
I have had a change to replicate your circuit and managed to get it working, as you showed. Thank you so much!
I was just wondering if I could ask the following..
What would be the advantage of using a cascode amplifier? If, indeed, there is one?
With a tuned circuit, would you have a series capacitor and inductor in parallel with the 820 ohm CE load resistor? How does this work to benefit the efficiency?
And what is the transformer action you mentioned? Is it good?!
Thanks again!
Mark
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
