oscilloscope specifications
terrakota
Joined Feb 8, 2005
67
i'm interestend in this pc based oscilloscope but i'm not sure if this one is rigth for me.
can u tell me the maximun voltage signal i can measure with this scope?
the maximun bandwidth i can measure?
PC Oscilloscope Specifications
General specifications
Input Channels: 7 internal, 2 external
Sampling Rate: 10 to 15,000 per second (PC dependent)
Overload protection: +30 volts
Digital Outputs: 1 TTL (With 1-3 k Ohm Impedance) 1 LED
Dimensions: 50 X 70 x 20 mm
Output Connector: 25 way male D-type to PC parallel port
Supplied Software: Picoscope, PicoLog, and additional software drivers
Internal Sensor Specifications
Channel Range Resolution Accuracy
Sound Waveform + 100 0.02 not calibrated
Sound Level 55 to 100 dBa 1dBa 5dBa
Voltage 0 to 5 volts 5 mV 3% of FSD
Resistance 0 to 1 MOhm 0.1 kOhm(at 10kOHM) 2% (at 100kOhm)
Temperature 0 to 70°C 0.1°C (at 25°C) 2°C (at 25°C)
Light 0 to 100 0.1 not calibrated
External Sensor Specifications
pH 0 to 14 0.02 pH calibrated dependent
Temperature -10 to 105°C 0.1°C (at 25°) 0.3°C (at 25°C)
Humidity 20 to 90%RH(N.C.) 0.2% RH + 10%
Reed Switch open/closed
thanks for your help
beenthere
Joined Apr 20, 2004
15,819
It's not too good for performance. The spec's say 5 volts max for input voltage. The i megaohm input impedance will limit it due to curcuit loading.
With 15k samples/sec, the fastest signal you might resolve is going to be 7,500 Hz. Using more channels will slow sampling per channel. This is not adequate for audio work, much less logic.
I don't think this device will be adequate for any realistic needs, other than a classroom demonstrator.
terrakota
Joined Feb 8, 2005
67
Originally posted by beenthere@Jan 4 2006, 09:29 PM
[post=12890]Quoted post[/post]​
thanks a lot for your info, will have to continue searching for more options.
JoeJester,
thanks for the link but $500 is really out of my capacity.
terrakota
Joined Feb 8, 2005
67
what about this one?
found it at amazon at $138.00 and is a portable one, can you tell me if it's any good?
http://www.amazon.com/gp/product/B0007ZPNH...6&s=hi&v=glance
Product Details:
10MHz sampling rate
0.1mV sensitivity
up to 2MHz analogue bandwidth
5mV to 20V/div in 12 steps
200ns to 1hour/div time base in 32 steps
full auto set up
trigger mode: run, normal, once, roll, slope +/-
X and Y position signal shift
DVM readout with x10 option
audio power calculation (rms and peak)
dBm, dBV, DC, rms ... measurements
signal markers for Volt and Time
frequency readout (through markers)
recorder function (roll mode)
signal storage (2 memories)
LCD: 128x64 pixels / high-contrast
up to 20h on alkaline batteries
