so if its a 12V relay, and coil resistance is 150 ohm. Ordinarily it would draw 12/150=80mA.Of course, you can do that, it depends on the voltage and current of relay, and you can calculate the limiting resistor, you can measure the Vce or just using the voltage about 0.9V~1.1v.
If I'd like to decrease it , maybe I'd add 1kohm resistor. So the current would be 12/1150=10mA. Would the relay still switch? There doesnt seem to be anything about it on the datasheet.
