Hello All
I want to design a small pcb (10mm across) to hold sensors. I also want to use thin flexible cabling to connect to them.
I would prefer not to solder the wires to the pcb.
I have been looking at crimp terminals in 1mm or 0.8mm pitch because only in these sizes would the pcb header be small enough, however, these usually require highly specialized and expensive crimping equipment.
Is there any other option?
Thank you
Thank you
