I am trying to turn on and off an LED that is contained within a small sack of sand. I am seeking a switch or sensor that will help me accomplish this goal.
Thank you for your time and consideration.
Curiously, "thyristor" is derived from the Greek θύρα meaning a doorSince you open and close an electronic circuit then do you turn on and turn off a door??
On the front it is marked "on" and "off", but the terminals are marked "n/o" and "n/c"A switch is usually marked "on" and "off".
Thank you for this suggestion.Check out the huge selection of Sensors for Car-Alarms.
Glass-Breakage, Short-Range-Field-Disturbance ( sometimes called "Radar"), Vibration, Tilt, etc., etc..
They're cheap and easy to work with.
Thanks for the suggestion! The LED will illuminate the fabric to create a soft glow that will be visible.A piezo disc connected to the gate of a small MOSFET will probably work.
But how will you know if the LED has illuminated?
I do not require that the LED turn on and off. Rather that the switch triggers an NE555 to keep the LED on for a duration. Thanks for prompting me to be more clear in explaining my needs for this project.But with your desire to do this once and have it on and one more time to have it off - a shaker switch isn't the best option. UNLESS you seal the shaker inside a non-conductive oil to dampen the movement.
Good point.On the front it is marked "on" and "off", but the terminals are marked "n/o" and "n/c"
by Don Wilcher
