op amp rail voltages
jrevard
Joined Jan 6, 2014
3
hi, how can I create the rail voltages for an op amp? the (+) voltage seems simple enough but I'm not sure how to supply the (-) voltage... I am seeing that for working with a DC signal the (-) terminal can be connected to ground but what about for AC signals?
thx
shteii01
Joined Feb 19, 2010
4,644
Depends on AC signal.
If AC is centered on zero, then your AC signal is from -X to +X volts. So you need to provide a negative rail.
If AC is centered on some positive value and the range of AC is, for example, from +1 to +5, then you don't need negative rail, just connect it to ground.
tubeguy
Joined Nov 3, 2012
1,157
+1
Using only a positive supply, if your AC signal is centered around 0 volts you can also deal with that by biasing the op amp's input at 1/2 the supply voltage using 2 resistors and coupling the input signal thru a capacitor.
shteii01
Joined Feb 19, 2010
4,644
If you don't need anything outrageous, you can use computer power supply, they usually have a couple negative voltages.
Brownout
Joined Jan 10, 2012
2,390
If you have two power supplies, you can connect them in series and use the wire between the two as 0V, or ground. They you'll have rails for + and -.
shteii01
Joined Feb 19, 2010
4,644
It was posted on these forums, but I found it with Google.
Connect -9 volts from the battery to the negative rail of the op amp. Connect +9 volts from the battery to the positive rail of the op amp. Connect the ground from the batteries to the circuit ground.
30,077
thx
The claim that you can connect the negative rail to ground if you are working with DC signals isn't a valid statement. As with AC signals, if the input and output signals are compatible with grounding the negative rail, then you can ground the negative rail. If they aren't compatible with a grounded negative rail, then you can't.
