Hi! I am working on a circuit that needs to produce biphasic square wave output of controllable + constant current nature. I am using an op amp configured as an integrator connected to a MOSFET as my VCCS (voltage-controlled current source). However, when the circuit is in conduction mode the output voltage of the op-amp momentarily spikes before reaching the desired level set by the feedback loop and in this period the output current spikes as well distorting the square wave. I need the output to be a clean square wave or at least the spike to be as short as possible. Can someone take a look at my circuit and suggest some possible changes? Thanks
the circuit in the image is connected to a mosfet h bridge above it
