Yes, the 1K resistor shown is in SERIES with the input.The schematic you posted shows 1k in series with the 10k pot to ground. Now you say you don't have a resistor from the +input to ground.
If you are changing the circuit, you need to post a schematic of what you are describing. We can't read your mind.
We can tell you the purpose of each resistor in an op amp circuit, but we have to know what the circuit looks like.
Based on the data sheet, I tried several resistors from the input to ground ALONG WITH the 1K resistor in series with the input.
Did you even look at the data sheet?
I didn't redraw the circuit because it's so simple anyone should be able to picture in their mind another resistor running from the noninverting input to ground.
As I stated above, this resistor had a direct effect on the offset with this particular device.
Nobody is asking you to "read my mind".
Comments like that I don't care for and contribute nothing to this thread!
