You don't need a scope. Why would you need anything other than the same tools that you used to measure the input and output for the data you've already given?I do not have a scope therefore, it might not be possible in the circuit because as I mentioned in my earlier post, the ramp generated by the integrator (the first half of KA358A) is fed into an external voltage cut-out device (VCO) which trips at some preset voltage. The output from the VCO is proportional to the ramp input until it trips. When the ramp reaches the preset value, the output is dropped to 735 - 750mV.
This output from the VCO is fed into the inv. amp (the 2nd half of KA358A). As long as this VCO-output is below the preset value, the output of the inv. amp is 0V. And when VCO-output is dropped to 750mV, the output of the inv. amp should rise to 12.7V (instead of 1.4V).
