Hi all,
I have tried to search for the answer to my question, but don't know the correct terminology so it has been difficult to determine what to search for.
I am modifying an old games console to contain an FPGA rebuild of the original console circuit board. The board requires 5v and has a micro-USB connector for the power, and I want to use the original power switch from the housing to switch it on and off. I have already wired up the original case's power switch to a micro USB cable so can use the original power switch to make and break the supply of power to the board.
The problem is that the board has a power button of its own which must be pressed in order to get it to power on. There is no way of getting it to power on automatically when current is provided. The power switch is non-latching so only needs to be pressed momentarily.
My plan is to power a relay circuit connected in parallel to the 5v supply coming into the case. This circuit should wait for a fraction of a second to make sure the console's main board is powered, then close the relay for a fraction of a second, and then open the relay again. The relay should not be triggered again until the console is fully powered off and on again. I can then solder wires from the output of the relay to the contacts for the board's momentary switch to simulate the pressing of the button.
I have found some relay timing circuits online, but because I don't fully understand the nomenclature I'm struggling to understand whether they are the right circuit, or if they are the best way of approaching it.
I'd really appreciate any help in advance!
