The problem Ernie is that you're talking about a linear oscillator and everybody else is talking about an inverting-gate relaxation oscillator. Or as you called it, a multivibrator. So most of what you've written is irrelevant. And frankly, your condescending attitude serves only to make you look like a wise guy. (Not to be confused with "wise man.")"Extraordinary claims require extraordinary proof." Somehow every reference on oscillation theory states the phase shift needs be a multiple of 360 degrees.If the "oscillator" has only two states (which it does because it is a logic gate), and has some hysteresis (ditto) it needs 180' phase shift from input to output. Which is why we use inverters.
A single RC is all it needs, to provide ANY time delay between the output changing state and the input following it.
If the entire world is wrong and you are right... start by checking your work.
I'm sorry, but that is simply not true. A multivibrator is a type of oscillator. Look up "electronic oscillator" in Wikipedia. Not all oscillators are linear.multivibrator != oscillator
