On-off Infrared Remote Control Schematic Help
Status
Not open for further replies.
tony18183
Joined Nov 21, 2011
1
Hi all, I am having problem on the implementation of the circuit. Can somebody show me howto build IC3 , IC2.A , IC2.B
what is D2? and (14)IC2(7) ?
many thanks
links: <SNIP>
praondevou
Joined Jul 9, 2011
2,942
This circuit is using a capacitive power supply, which cannot be discussed on AAC according to the ToS.
D2 is a zener diode clamping the voltage for the low voltage part to 15V.
If you use instead of C5 a small transformer and a rectifier after it your control circuit can be made galvanically isolated from mains and we will be able to help you.
Even worse you will be using 230V. When testing a circuit like this you would need to be very careful to not get electrocuted when inverting the input.
Wendy
Joined Mar 24, 2008
23,421
I am afraid I have to agree.
I am closing this thread as it violates AAC policy and/or safety issues. When dealing with power supplies you must use a transformer.
Quote:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
Status
