I am not an electronics person, although I have a basic understanding of gates, transistors, etc. I would like to make a circuit that would have an incoming voltage of 24v 1amp and switch the output to one of two outputs each time the incoming voltage goes high or low. ie: input high output to A, input is off no output to either Outputs A or B. Input goes high again output goes to B. input goes off and output switches to off. the output would be 24v 1amp same as the input. this would be a repetitive cycle between outputs A and B. Thanks in advance.
