nixie clock, bit of a heating problem
magnet18
Joined Dec 22, 2010
1,227
OK, it's all working, and the case is most of the way constructed, battery backup and diode gates work like a charm, there's just one little thing left
when the tubes are off, the entire circuit (all 12 IC's) draws 28mA, not even enough for my power supply to realize power is even being drawn (it wont light up, but still provides power, so i dont care)
When the tubes are on, it draws ~205-230 mA, quite a bit
this all leads me to believe that the tubes and their powering circuitry is drawing about 200mA, which is to be expected.
Apparently, however, when powering all tubes with a single 555 and FET, the chip and fet get quite warm. I ran it for over an hour, and nothing failed, it was just warm enough to feel; probably around 90F
So, this bothers me a bit. As I understand, my options are-
add a heatsink
add a fan
use bigger parts
use 2 tube power supplies (was the idea originally but one died, and I never got around to re-doing it)
or any combination
are there any other, easier options, or will any one of those work, or should I not worry about it?
thoughts?
thatoneguy
Joined Feb 19, 2009
6,359
What is your plate voltage?
How much current does each "segment"/number draw?
The nixie drivers I've seen provide 155V@20mA for the nixie tubes, and 5V@200mA for the logic.
magnet18
Joined Dec 22, 2010
1,227
Yea, each tube should draw like 5 ish mA, each neon like 2, so 2*5+5*6=40mA the power supply puts out 180 volts which is dropped to <170 by the current limiting resistors
during normal operation (earlier numbers were on start-up, 'lytics were charging) the power supply draws like 180mA, so it is very inefficient :(
[EDIT]
wait, I forgot to math
.180A*12V=2.16W
.04A*180V=7.2W
300%efficiency, woo!
:p
(someone show me where I went wrong please)
[EDIT EDIT]
My bad, 2.5 mA per tube, silly me :rolleyes:
that makes 10+2.5*6=25mA
.18*12=2.16W
.025*180=4.5W
now were down to 200% efficiency... where else did I go wrong???
thatoneguy
Joined Feb 19, 2009
6,359
Are the tubes glowing extremely bright? Have you measured the DC plate voltage and current?
What is your HV supply rated for? Which part is getting hot?
kubeek
Joined Sep 20, 2005
5,795
If the mosfet is so far without heatsink and reaches less than your body temperature I wouldn´t worry about it. I don´t know what frequency is your 555 running at and what is the gate resistor, but the rule of thumb (at least for power devices) is that if you can hold your finger onto it then it is cool enough, higher than that you should start thinking. You should not be alarmed by "slightly warm".
thatoneguy
Joined Feb 19, 2009
6,359
Kubeek reads posts better than I do.
If you can actually hold your finger on the FET but think "this is warm" after it's been running an hour, you don't have a problem.
I thought it was getting warm instantly. I would hazard a guess that the FET isn't being driven hard enough for switching in the boost supply, hence the losses.
Quick way to tell: Is the switching frequency or voltage far off from what you calculated when building it?
magnet18
Joined Dec 22, 2010
1,227
Oh, I didnt know you guys were posting, I should have refreshed :p
Check my edits in the above post
also, I wont worry about it, it warms up quickly, but stabilizes at a temperature I can hold my finger on
Can anyone help me with the above math?
and... I didn't actually calculate anything when building it, I just sorta put it together
thatoneguy
Joined Feb 19, 2009
6,359
Then you don't have a problem.
Is only 1 segment lit at a time and you are calculating for the full load? try labeling what numbers represent which item.
Then you are doing great!
magnet18
Joined Dec 22, 2010
1,227
ok, apparently I can't remember current numbers :p
neon-.7mA
neon-.7mA
neon-.7mA
neon-.7mA
neon-.7mA
tube-2.5A
tube-2.5A
tube-2.5A
tube-2.5A
tube-2.5A
tube-2.5A
18.5mA*180=3.33W
220mA*12=2.76W
BUT!!
only 3 neons are on at a time!
so it's 3.07W
and the tubes are being limited to closer to 2.2mA, so it's 2.754W!!
It is apparently quite efficient :D
I'll have to take some real voltage and current ratings of the high side later, see what they actually are
SgtWookie
Joined Jul 17, 2007
22,230
I thought I told you that it would be somewhere around 90% efficient when I first showed you that circuit many moons back.
At any rate, I don't recall what the gate resistor is, and whether there is a diode in parallel with it.
You really need to post schematics along with your questions, as all anybody can do unless they are really familiar with your circuit is to make rather general statements. I don't have any of my files with me.
magnet18
Joined Dec 22, 2010
1,227
You're back!!
How are you?
and general statements were all I was really going for, as I was wondering how to best keep the chip cool
(also, I thought 90% was for a different buck-boost you were helping someone with in spice that you suggested)
just one of the 555 circuits
SgtWookie
Joined Jul 17, 2007
22,230
Ah yes. You're using an IRF840 MOSFET. That's rated for 500V, which is maximum overkill.
You could likely get away with an IRF620 or IRF630, and it would run a good bit cooler, as the gate charge would be much lower as well as the Rds(on) being lower.
Also, you need a gate resistor of between 20 and 40 Ohms, and a diode in parallel, anode towards the MOSFET. Otherwise, you wind up with a series LC circuit that will ring like the dickens without any snubbing.
