I am wiring a commercial 24th scale slot car track and I want to use big chassis mount NFETs to connect each lane instead of the typical relay. It is a high side connection, I will use a separate power supply to get the 10 volts Vgs.
Why? Just because it's better?. No deterioration over time and way less on resistance. And of course way less power to turn on.
Is there any reason not to do this? Attached is the data sheet for one of these fets
https://www.mouser.com/datasheet/2/205/Viewer-765418.pdf
