I once saw a unit with a single bimetallic probe, that merely held a "relay" closed. As I recall, the relay had an actuator button on it, and the user put the probe in the fluid and pressed the actuator on the relay. If the fluid dropped, or the probe lifted, or anything went wrong, the N/C contact closed, which was monitored. In this instance an indicator light and a "piezzo" buzzer sounded. The probe had a cupric alloy on one face, and zinc or aluminum on the other face, with an insulating material between, which the metallic faces were bonded to. I believe the probe was a few inches long.
Of course, this is a galvanic circuit, and the electrochemical mechanism is known as a "cell". It would take 2 or more connected in series to obtain what is known as a "battery"...... wouldn't it!
