I've discovered a new material for already knows thermal toner transfer pcb method. It's about vinyl sticker. You can see a free tutor at http://electroni-city.com.
I realy tried to share with electronic hobbyist a new material for toner transfer method. I've made this new material (in fact not new but related to pcb is new) which works very well. Try it.It's spam for sure, but the site has legit toner transfer tutorial and no ads, and not selling anything. weird.
You're right. I'm very excited and proud about my method. I don't know where do you get the vinyl but I can say you the exactly type of it. It's about 'Oracal' 640, 641, 651 vinyl sticker foil. You can search for it on the web. You can use any vinyl sticker foil that can resist at minimum 170 gr. celsius. You may go at your supermarket and search for any 2,5-3,5 mil thickness vinyl foil or roll. Try it on your printer (in small amount of it) to see if no melt after print. Success!I saw your similar posts in forums all across the web. What you are doing is typical of spammers, but I don't see any motive for spam. Your website contains no ads and is selling nothing. It is an odd thing to see. I guess you are just very excited about your method? It is interesting. Where do you get the vinyl? I may try it.
No. The active part is the vinyl foil, not the paper on its back. You can use it, but you get more accurate results with the vinyl. If you go for the paper you must first remove the vinyl and then print on the remaining glossy paper. The main difference between glossy paper (including the photo paper) and the vinyl film is that the vinyl allows the toner to keep its height even when under pressure - while the vinyl softens/melts, the toner gets harder. And this is the secret.According to the Oracal website the film (if I understood the tutorial right) works because of the backing paper. The OP is saying to print on the backing, correct?
From the website - " 84# custom silicone-coated paper with special release characteristics that provide excellent weeding and release values. Customized blue silicone paper liner for white provides superior contrast for cutting and weeding. "
Website - http://www.oracal.com/products/product.asp?seriesID=218&tabID=ts
Thank you for your suggestions. I'll make the changes acordingly your proposal.Several things to say.
First, another link to a US seller of the film.
Your words are very well translated and understandable except for a few.
On the page, "PCB Tinning" it is said, "alcohol or isopropyl alcohol". There are several alcohols that might fit this description like, ethyl alcohol, denatured (ethyl) alcohol, methyl alcohol. Still, isopropyl alcohol is easy to obtain.
Isopropyl alcohol is ok.
nitrocellulose solvent is not well known among electronics people in the USA. Can you give another name like, acetone, or xylene, or mineral spirits?
Acetone is ok. Another word could be thinner?
the word, "tin" would be "solder" in American English, unless you actually mean the element Sb, subnium, tin, (not including lead).
"Stoned would be, "deburred" in American.
"Grinding" would be, "polishing" in American.
I see you are using "2000 wet&dry sandpaper" for polishing.
A "rubber" is an "eraser" in American.
I do not know if I'm being helpful but I'm trying to be helpful.
Have any questions? Just ask me.Sorry misunderstood the tutorial.
