Hi everyone,
I am working on a board which is in quite bad condition, bit of corrosion etc. I found this smd polarized capacitor with some kind of bulging on the side. Not sure if its some kind of glue or if the capacitor is bulged. It looks kind of white - I tried scrapping some off but it didn't work I didn't apply too much force as I didn't want to damage the capacitor. I haven't seen this kind of failure before, normally I see brownish substance leaking from electrolytic capacitors (through hole). Any idea how to confirm this? I can't get a meaningful reading from the meter, I don't want to remove it without getting a spare in. While I'm on this topic any idea where I could source these kind of capacitors seems to be a bit hard to come by.
This board is a Mini-ITX motherboard (LV-67H), do you guys think that I could use an ultrasonic cleaner to clean off the gunk off this board, especially with the processor is exposed like this.
Thanks in advance
Thanks in advance
