Need to make 4 - 20mA loop isolators
bowlingo
Joined Jun 29, 2011
162
Hi all,
I have a combined PH and CF transmitter of which can be found here
http://www.omega.co.uk/ppt/pptsc.asp?ref=CDTX300
I need to make 2 x 4 - 20mA loop isolators that I can connect to each output. The unit runs on a 24V power supply
Someone has pointed me to some of the components
http://docs-europe.electrocomponents.com/webdocs/0028/0900766b800289f3.pdf
http://www.rapidonline.com/Electric...106/?sid=003c3b70-f289-488d-b4a3-bb276c21a821
This will be the fist time I have made something like this and would like to do it on small prototype boards with chip housings etc.
Can anyone provide me with the correct parts from farnell or RS and possibly an easy to understand diagram?
Thanks
30,821
I would assume that if two readings are transmitted via a two wire interface, then this is a digital output. You will need a digital processor such as a microcomputer to interrogate the data.
bowlingo
Joined Jun 29, 2011
162
This is the unit I have used on it in the past
http://uk.rs-online.com/web/p/produ...552267573743D343636323231342677633D4E4F4E4526
As you can see its disgustingly expensive £134.40 including VAT
I am sure these can be made easily using basic components and a bit of soldering..trouble is what components from RS or Farnells, chip housing etc and a wiring diagram...I would like to use the existing 24V DC supply
Thanks
30,821
I can never figure why people say it must be easy to do and they come running to us for help.
bowlingo
Joined Jun 29, 2011
162
That is a very good point..can anyone who knows how to do this help me please as quite rightly as mrchips has pointed out its not easy to do hence the reason I am asking
bowlingo
Joined Jun 29, 2011
162
I believe that's the same device my first reference op note discusses.
If you want true isolation that circuit won't do. You need an added isolator as shown in the op note. Otherwise you can just power it from a DC supply within the circuit's voltage limits of operation.
Thanks for your help...can you help me out with the exact components?....I really would like to make this and test it
34,459
If you want a cookbook design here's a circuit shown in Figure 19 of this ap note.
Edit: The circuit parts are readily available and low cost. It uses an optocoupler for high isolation between input and output.
