Anybody know if or what types of chips you need to filp left to right of composite video input?
what are you trying to do,
do you want to scan from right to left instead, why not reverse the line scan coils?
Once a TV came into the workshop with the horizontal yoke reversed.Maybe the OP is using a digital monitor. I know mine doesn't have deflection coils.
I think he would would a LIFO memory.The TS probably needs a dual line buffer - one loading a line while the other plays back.
FIFO memory if you can still get it.
For some reason; I was thinking of shift registers in the simplest sense where bits follow through as clocked.I think he would would a LIFO memory.![]()
