Apologies. I should have said the negative side of the timing cap would be connected to ground.A 555 will not do anything if its pin2 is connected to ground. Pin2 normally connects to pin6 and the timing capacitor.
If you want the CD4017 to stop after 9 outputs then connect the 10th output to a transistor inverter that resets the 555's pin4.
Regarding the transistor inverter, are you referring to pin 4 of the 555 oscillator that's on the chaser board, or the 555 monostable that will be switching power to that oscillator? I thought of the same thing, sort of. I was going to try a NPN on the 10th output (resetting pin 4 of the 555 monostable) but leave the LED in there as well. I'd prefer to get all 10 LEDs lighting if possible. I can live with 9 outputs if necessary, though. Thanks again!
