thatoneguy
- Joined Feb 19, 2009
- 6,359
Simplicity. How is the 1s calculated, or is it a "Close to 1 Second w/2N7000"?Just to throw another monostable/power-on-reset circuit option into the mix.
Ken
Ken
On that note, be sure to order automotive rated caps for any electrolytics, they are a bit more expensive, but worth it. Cars are about the harshest environment one can put electronics into, next to space.Great job guys. In Multisim is working. I will make the real pcb and waiting for some sunshine to come....is very cold outside to wire the circuit in the car
Are you getting kickbacks from Linear. I've seen this link 3 times today! He He.I posted this in a different thread... have a look at these:
http://parametric.linear.com/html/timerblox
Mike T.
No, just trying to be helpful. Lot's of people looking at 555 circuits, these are simpler. Did you know about them before I posted the link?Are you getting kickbacks from Linear. I've seen this link 3 times today! He He.
iONic
Mike,No, just trying to be helpful. Lot's of people looking at 555 circuits, these are simpler. Did you know about them before I posted the link?
Mike T.
OFF TOPIC: Pardon me. I didn't see anything about being this being a one-off project. Nor that it had to be through-hole, reflect a certain price range or any particular voltage. From my perspective, one-off projects are not normally subject to a price cap. 2-5 volts; a resistor and a zener. Output 20mA; more than enough to turn on a FET. SMT; I think I saw in the thread something about being "smaller and less power than using a relay". I see question after question answered with "555" and all the convolusions gone through to make them work. I suggested an alternative, that's all. If you had never wandered past the 555 you are now aware of them. "Unqualified replacement"? I don't think so.Mike,
A big issue is cost and availability for a one-off project. Digikey has them for ~$3 each in single quantities. Also, the packages are only in surface mount, the voltage is 2-5V, the output is 20mA... There are definitely places for them, but for general hobby projects, they have many limitations. I sort agree with iONIc, in that I think it is best to suggest them for projects where their packages and parameters shine, not just an unqualified replacement for 555s.
Ken
by Duane Benson
by Aaron Carman
by Aaron Carman
by Jake Hertz
