I see no reason why a couple of phototransistors, a couple of comparators, and an H-bridge driving a motor would need ±power supplies.See Post #23. Use a switcher to generate your supplies. You could use a single 1.5V cell if you really wanted to.
No, the LDRs change resistance from about 20K to about 5K (actually it depends on the specifications). There will always be some current going through the LDRs. What happens in this circuit is that the ratio can change from about 4:1 (2V for Vcc=10V) to 1:4 (8V).
It seems like the bottom ldr is in series and dependent on the top ldr. If this is true how can the bottom activate it's comparator(s) and turn the motor without light also shining on the top. Should I assume that light is shining to some degree on top (enough to let current through) before I begin to imagine how current might be flowing through the circuit?
Ditto on linux. Thanks.geda, oregano, eagle, electric, and spice are a few that i can think of that may serve the purpose but there are a lot more
long time linux user
We are not mind readers. Just saying that "because it's not working" gives us absolutely nothing to go on when it comes to helping you.I'm trying to hook up a comparator and I'm pretty sure I got the wrong one because it's not working. I got an lm399 from radioshack. It says Vcc is (+36 or ±18V), I'm operating on 3 volts. Can any one point me to the right comparator? I'm having trouble finding one with a low supply voltage.
http://www.engineersgarage.com/electronic-components/lm339-datasheet
LM339 it says. It says supply voltage: +36VDC or 18VDC. Hmm..Reply to post #49:
You have the basic understanding of the right side of the circuit.
The lower LDR does serve a useful purpose. It changes the voltage on the comparator input from 8V to 2V. If it was replaced by a fixed resistor (10K), the voltage change would be much less 6.6V to 3.3V.
Reply to post #51:
Did you get LM339 or LM399? You should have LM339. The datasheet allows the LM339 to have a supply anywhere between 2V and 36V. So it should work if you are using 3V.
Operating on 3V should be fine because the 36V is the MAXIMUM supply voltage you can use. The minimum is 2V.
I'm willing to go out on a limb and bet that you aren't taking into account that the LM339 (and it definitely appears that you are NOT using an LM399 since the link you gave goes to an LM399 and I would be surprised if Radio Shack carried anything but an LM339 any more) has open-collector outputs. This means that the outputs can only assert a LO level actively and, when they want to output a HI they basically disconnect the internal circuitry from the output pin, requiring that the external circuit pull the output node HI. This is usually done by connect a passive pullup resistor between the output and Vcc. Depending on your speed requirements and how capacitive the load is on the output pin, something like a 1kΩ is probably a reasonable place to start. Making is smaller will make the changes faster and get the output closer to Vcc, but will consume more power when you are outputing a LO. Conversely, making it bigger will make it slower and leave you with a lower output voltage when it is HI, but will consume less power. Like everything in engineering, it's a compromise.
Your light years ahead of me... This seems more complicated then I was imagining.... If the output can flip flop between positive and ground states, hooking a resistor between Vcc and the output pin seems scary. I don't think I'm in need of disconnecting the output pin though (I don't know). Maybe it is working and I'm getting confused by the LO signal. Could this be? I tried push this "LO" signal through a transistor but it didn't open the gate for actual work to be done.external circuit pull the output node HI.
I'm chose to use one comparator and experiment. I hooked it up like this:
- Vcc hooked to positive rail (3 volts)
- GND to negative terminal on batteries
- Input 3- (as reference) I first kept it disconnected thinking it should give me peak signal. I also tried with a 200k resistor.
- Input 3+ to full 3 volts
Do not leave ANY inputs unconnected (this pretty much applies to any chip, but there are exceptions). You want to define the + and - input signals for any comparator you are using, and you want to place any comparators you are not using into well defined states. This is most easily done by connecting the + input to Vcc and the - input to ground (or the negative supply rail). Do not connect them to the same level as this can result in them flailing around and injecting noise into the chip and, potentially, other circuits via the power supplies.
Why is it scary? The output stage of each comparator is nothing more than an NPN transistor with the collector tied to the output pin. When the internal circuitry wants to take the output LO, it turns on this transistor. When the internal circuit wants to allow the external circuitry to pull the output HI, it turns off this transistor.Your light years ahead of me... This seems more complicated then I was imagining.... If the output can flip flop between positive and ground states, hooking a resistor between Vcc and the output pin seems scary. I don't think I'm in need of disconnecting the output pin though (I don't know). Maybe it is working and I'm getting confused by the LO signal. Could this be? I tried push this "LO" signal through a transistor but it didn't open the gate for actual work to be done.
NO!!!!So when the output signal is "LO" I need to force it to go "HI" with a pull up resistor like you mentioned? And when the output is not "LO", it is OFF. So the output toggles between these two states: LO(0.3V)=ON and 0V=OFF. Is this correct?
by Jeff Child
by Jake Hertz
by Aaron Carman
