Need help with component on key remote
Mig4236
Joined Feb 4, 2020
12
My remote for my c4 Corvette stopped working. I'm not sure what this component is but I can here something moving or rattling inside it. Any help would be appreciated.IMG_20200204_231617__01.jpgIMG_20200204_231149__01.jpgIMG_20200204_231632.jpgIMG_20200204_231722.jpg
narkeleptk
Joined Mar 11, 2019
532
@Mig4236 I work with a lot of remotes, rarely is it worth trying to repair them but if you take a photo of both sides of it I may can offer some advice on what commonly goes bad.
Yes, I don't know why it would be there or if it is rare or common, but I can't think what else it could be.
I have never seen them in one before so definitely not common but old GM remotes never fail to amaze me.
Mig4236
Joined Feb 4, 2020
12
These keys are rare and expensive so I'm willing to see if I can fix it.
Mig4236
Joined Feb 4, 2020
12
I used a microscope. It looks damaged. Just need to figure out what it is.
AlbertHall
Joined Jun 4, 2014
11,393
If you have a multimeter they are not difficult to test. Remove the battery from the fob, then connect your mrter on a low ohms range between the cylindrical case and the pin sticking out of the end. As you move the fob to differnt angles you should see that sometimes it is high resistance and sometimes it is a near short circuit.
Mig4236
Joined Feb 4, 2020
12
Yes I see on my multimeter. It goes high then low
narkeleptk
Joined Mar 11, 2019
532
Thinking about it now, these old vettes have a odd "PKE" (passive keyless entry). It could possibly be a switch so that when the key is placed around the car and not in use the signal is cut off and does not make the locks on car go crazy. Then when your using it or walking to the car , etc..., its likely to be shuffled around enough to make contact and allow the pke system to function as normal. I bet @AlbertHall is correct. Its a movement sensor.
Mig4236
Joined Feb 4, 2020
12
You think that would cause the key not to work?
