need help with analyzing circuit
ErnieM
Joined Apr 24, 2011
8,377
For the most part the values were chosen because they seem to work. I doubt the long term reliability of this circuit given IC3 is shorting out C5 and is thus overstressed.
The author gives a decent enough description, you should start there, then come back with any specific questions you have. No one is going to work this out for you as it would take hours for any kind of detailed analysis.
17,496
No. Why in the world would the designer put them there if they had no function?
If you're asking if you could create a simpler IR-triggered remote switch without those parts, then yes. But it won't have the same features as that design.
