i put a 1us delay between after every line in the code coz according to the lcd timing diagram its about 300ns, the other group used Lcd_init(&PORTD), but it doesn't work/build in mikro c pro. here is our final code till now , THX FOR THE HELP.
Rich (BB code):
sbit LCD_RS at RA3_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RD4_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D3 at RD3_bit;
sbit LCD_D2 at RD2_bit;
sbit LCD_D1 at RD1_bit;
sbit LCD_D0 at RD0_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_RS_Direction at TRISA3_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
sbit LCD_D3_Direction at TRISD3_bit;
sbit LCD_D2_Direction at TRISD2_bit;
sbit LCD_D1_Direction at TRISD1_bit;
sbit LCD_D0_Direction at TRISD0_bit;
#define RS PORTA.RA3
#define E PORTA.RA1
#define RW PORTA.RA2
unsigned int temp_res;
void MSDelay(unsigned int d);
void main(void) {
unsigned int t;
char Temp[8];
ADCON0=0x81;
ADCON1=0x8E;
TRISA=0x01;
TRISC=0;
TRISD=0;
TRISE=0;
PORTE=0x1;
do {
temp_res = ADC_Read(0); // Get 10-bit results of AD conversion
temp_res = temp_res *0.486;
PORTD = temp_res ; // Send lower 8 bits to PORTD
t=PORTD;
inttostr(t,Temp);
RS=0; // initiating the LCD
RW=0;
delay_us(1);
E=1;
delay_us(1);
LCD_init();
delay_us(1);
E=0;
delay_us(1);
RS=0; // Clearing the LCD Display
RW=0;
delay_us(1);
E=1;
delay_us(1);
Lcd_Cmd(_LCD_CLEAR);
delay_us(1);
E=0;
delay_us(1);
RS=1; // Writing Temperature to the LCD
RW=0;
delay_us(1);
E=1;
delay_us(1);
lcd_out(1,4,"Temp.");
E=0;
delay_ms(1);
RS=1; // Writing Temperature Value to the LCD
RW=0;
delay_us(1);
E=1;
delay_us(450);
lcd_out(2,5,Temp);
E=0;
if(t>=20 && t<30)
PORTC=0x2;
else if(t>=30)
PORTC=0x2;
PORTC=0x3;
else
PORTC=0X0;
RS=0; // Removing the cursor
RW=0;
delay_us(1);
E=1;
delay_us(1);
Lcd_Cmd(_LCD_CURSOR_OFF);
delay_us(1);
E=0;
delay_us(1);
} while(1);
