HI.I'M WORKING FOR MY FINAL YEAR PROJECT WHICH IS I MAKE TO MAZE MAPPER ROBOT.FOR THIS PROJECT I USE 3 IR SENSORS (sharp GP2D120XJ00F),2 12VDC MOTOR WITH ENCODER (PD3046) AND 1 PIC18F4550 MICROCONTROLLER.I HAVE MAKE THE SENSORS CODING SEPARATELY BUT I CAN'T COMBINE THE 3 SENSORS CODING INTO 1 CODING.I'VE TRIED TO COMBINE THE SENSORS CODE BUT IT'S DOESN'T WORK AT ALL.HOW CAN I COMBINE THE 3 SENSORS?THERE'S ANYBODY CAN HELP ME TO SOLVE THE PROBLEM.FOR YOUR INFORMATION, I CONNECT THE 3 SENSORS AT THE PORTA0-A2.I ATTACH MY SENSORS CODE BELOW:
COMBINATION OF 3 SENSOR
define osc 8
defenition
DEFINE CCP1_REG PORTC ' Hpwm 1 pin port
DEFINE CCP1_BIT 2 ' Hpwm 1 pin bit
DEFINE CCP2_REG PORTC ' Hpwm 2 pin port
DEFINE CCP2_BIT 1 ' Hpwm 2 pin bit
DEFINE ADC_BITS 8 ' Set number of bits in result (8, 10 or 12)
DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in microseconds
MRCW1 VAR PORTD.4
MRCCW1 VAR PORTD.5 'MOTOR RIGHT DRIVE
MRCW2 VAR PORTD.6
MRCCW2 VAR PORTD.7 'MOTOR LEFT DRIVE
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA=1
ADCON1=%00001110
SENSOR1 VAR BYTE
SENSOR2 VAR BYTE
SENSOR3 VAR BYTE
HPWM 1,150,1000
main program
MAIN:
GOSUB fwd
pause 1000
GOSUB IR1
PAUSE 1000
GOSUB IR3
PAUSE 1000
GOSUB IR2
PAUSE 1000
GOTO MAIN
FWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
HPWM 2,150,500
MRCCW2=1
MRCW2=0
RETURN
IR1:
ADCIN 0,SENSOR1
IF SENSOR1>46 THEN
GOSUB RIGHT
pause 1000
ELSE
if SENSOR1<46 THEN
GOSUB FWD
pause 1000
ENDIF
ENDIF
pause 1000
RETURN
IR2:
ADCIN 1,SENSOR2
IF SENSOR2>46 THEN
GOSUB BWD
pause 1000
ELSE
if SENSOR2<46 THEN
GOSUB fwd
pause 1000
ENDIF
ENDIF
pause 1000
RETURN
IR3:
ADCIN 2,SENSOR3
IF SENSOR3>46 THEN
GOSUB LEFT
pause 1000
ELSE
if SENSOR3<46 THEN
GOSUB FWD
pause 1000
ENDIF
ENDIF
pause 1000
RETURN
RIGHT:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
HPWM 2,150,500
MRCCW2=0
MRCW2=0
RETURN
LEFT:
HPWM 1,150,500
MRCCW1=0
MRCW1=0
HPWM 2,150,500
MRCCW2=1
MRCW2=0
pause 1000
RETURN
BWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
HPWM 2,150,500
MRCCW2=1
MRCW2=0
PAUSE 1000
GOSUB RIGHT
RETURN
FOR THE SEPARATE CODE OF SENSOR:
SENSOR 1
define osc 8
'defenition
MRCW1 VAR PORTD.4
MRCW2 VAR PORTD.6
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA.0=1
ADCON1=%00001110
SENSOR1 VAR BYTE
HPWM 1,150,1000
'main program
MAIN:
GOSUB fwd
pause 1000
GOSUB IR1
GOTO MAIN
FWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
RETURN
IR1:
ADCIN 0,SENSOR1
IF SENSOR1>46 THEN
GOSUB BREAK
ELSE
if SENSOR1<46 THEN
GOTO MAIN
ENDIF
ENDIF
pause 1000
GOTO IR1
BREAK:
HPWM 1,150,500
MRCCW1=0
MRCW1=0
RETURN
AND FOR SENSOR 2
define osc 8
'defenition
MRCW1 VAR PORTD.4
MRCW2 VAR PORTD.6
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA.1=1
ADCON1=%00001100
SENSOR2 VAR BYTE
HPWM 1,150,1000
MAIN1:
GOSUB FWD
pause 1000
GOSUB IR2
GOTO MAIN1
FWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
pause 1000
RETURN
IR1:
ADCIN 1,SENSOR2
IF SENSOR2>46 THEN
GOSUB BREAK
ELSE
if SENSOR2<46 THEN
GOTO MAIN1
ENDIF
ENDIF
goto IR2
BREAK:
HPWM 1,150,500
MRCCW1=0
MRCW1=0
RETURN
PLEASE HELP ME,I'M DESPERATELY NEED THE SOLUTION OF MY PROBLEM.THANK YOU.
define osc 8
defenition
MRCW1 VAR PORTD.4
MRCW2 VAR PORTD.6
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA=1
ADCON1=%00001110
SENSOR1 VAR BYTE
SENSOR2 VAR BYTE
SENSOR3 VAR BYTE
HPWM 1,150,1000
main program
MAIN:
GOSUB fwd
pause 1000
GOSUB IR1
PAUSE 1000
GOSUB IR3
PAUSE 1000
GOSUB IR2
PAUSE 1000
GOTO MAIN
FWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
HPWM 2,150,500
MRCCW2=1
MRCW2=0
RETURN
IR1:
ADCIN 0,SENSOR1
IF SENSOR1>46 THEN
GOSUB RIGHT
pause 1000
ELSE
if SENSOR1<46 THEN
GOSUB FWD
pause 1000
ENDIF
ENDIF
pause 1000
RETURN
IR2:
ADCIN 1,SENSOR2
IF SENSOR2>46 THEN
GOSUB BWD
pause 1000
ELSE
if SENSOR2<46 THEN
GOSUB fwd
pause 1000
ENDIF
ENDIF
pause 1000
RETURN
IR3:
ADCIN 2,SENSOR3
IF SENSOR3>46 THEN
GOSUB LEFT
pause 1000
ELSE
if SENSOR3<46 THEN
GOSUB FWD
pause 1000
ENDIF
ENDIF
pause 1000
RETURN
RIGHT:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
HPWM 2,150,500
MRCCW2=0
MRCW2=0
RETURN
LEFT:
HPWM 1,150,500
MRCCW1=0
MRCW1=0
HPWM 2,150,500
MRCCW2=1
MRCW2=0
pause 1000
RETURN
BWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
HPWM 2,150,500
MRCCW2=1
MRCW2=0
PAUSE 1000
GOSUB RIGHT
RETURN
SENSOR 1
define osc 8
'defenition
MRCW1 VAR PORTD.4
MRCW2 VAR PORTD.6
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA.0=1
ADCON1=%00001110
SENSOR1 VAR BYTE
HPWM 1,150,1000
'main program
MAIN:
GOSUB fwd
pause 1000
GOSUB IR1
GOTO MAIN
FWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
RETURN
IR1:
ADCIN 0,SENSOR1
IF SENSOR1>46 THEN
GOSUB BREAK
ELSE
if SENSOR1<46 THEN
GOTO MAIN
ENDIF
ENDIF
pause 1000
GOTO IR1
BREAK:
HPWM 1,150,500
MRCCW1=0
MRCW1=0
RETURN
AND FOR SENSOR 2
define osc 8
'defenition
MRCW1 VAR PORTD.4
MRCW2 VAR PORTD.6
TRISD.4=0
TRISD.5=0
TRISD.6=0
TRISD.7=0
TRISA.1=1
ADCON1=%00001100
SENSOR2 VAR BYTE
HPWM 1,150,1000
MAIN1:
GOSUB FWD
pause 1000
GOSUB IR2
GOTO MAIN1
FWD:
HPWM 1,150,500
MRCCW1=0
MRCW1=1
pause 1000
RETURN
IR1:
ADCIN 1,SENSOR2
IF SENSOR2>46 THEN
GOSUB BREAK
ELSE
if SENSOR2<46 THEN
GOTO MAIN1
ENDIF
ENDIF
goto IR2
BREAK:
HPWM 1,150,500
MRCCW1=0
MRCW1=0
RETURN
