- Joined Jan 23, 2018
- 14,653
The reason stock size matters a lot is because the feed rate prior to starting to cut is much faster than the feed rate can be once it engages the stock it is cutting. You can approacjh at 2 inches per second but you can't cut steel that fast..Works when doing it manually- but how well does that work when nobody is home?
