I need help to find a way to insulate a few hundred 50mm spindle motors from the 6061 aluminum motor mounts they will go in. I can anodize the motor mounts with something like a type III hard finish that can build up a .002 to .003" nonconductive layer. But I'm a little worried that in the process of mounting and remounting the motors the anodizing can get damaged and allow a current to pass. The motor mount also serves as a heatsink so I don't want to add a layer between the surfaces unless absolutely necessary. The motor mount halves will also be tightened up quite firmly against the motor.
The red area in the image is steel and conductive. Blue motor mounts shown in blue come in raw 6061 aluminum.
I 3D printed a spacer out of PETG to test but it softened up and caused issues. The motor temp running is about 85C/158F.
