k then thanks..ill give it a try..but what about the 2004...what can i use instead of that 1..is there an alternative that i may have???
Why don't you look at the datasheet for a 555 timer, and see what the formula for determining the cap and resistor values might be?ok...well never mind i found the 1uF...
if i change the resistors would i still have to change the capacitors or could the capacitors stay the same
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Duane Benson
