I am pretty sure you can figure out the details, too, because I showed you every one of them. I showed you the math, I showed you the tolerances, I validated every part number and every drawing, I drew a schematic for you...I did everything except tell you what the black stripe on the diode means, and I did not link you to an SSR. I gave you the datasheet for a mechanical relay, 2.4 volts, DPDT. I checked the relay current against the diode current abilities, I checked the diode maximum voltages.
If you want to know what the black stripe means, it is on the datasheet, page 2, figure 1.
