Need help finding a possible solution to a problem - any ideas welcome!
TCU
Joined Sep 11, 2009
5
here are my requirements -
I need to connect an oscillator to excite a sensor
simultaneously, I need to collect the signal from 3 other sensors and amplify it (ideally using one amp).
Lastly, of the 4 sensors, I need to be able to switch the excitation source.
This is not a book/class but rather a real life problem so any help ideas or direction is appreciated. I just don't know what's out there.
Thank you!
Bernard
Joined Aug 7, 2008
5,784
If signal levels are compatable, try using 2 4066 IC's, one to switch oscillator ,one to connect sensor to amplifier. If they are to be switched in a continuous sequence, drive 4066's with 4017 or 4022 & 555 as clock.
