Hi SgtWookie, Where to increase the cap? Is that on 556 control/reset pin? Thanks, Kevin
M Thread Starter mpcotuong Joined Aug 26, 2010 170 Jun 17, 2011 #21 Hi SgtWookie, Where to increase the cap? Is that on 556 control/reset pin? Thanks, Kevin
SgtWookie Joined Jul 17, 2007 22,230 Jun 17, 2011 #22 How many 220uF capacitors do you see in the schematic you originally posted? That is the one that I mean for you to increase.
M Thread Starter mpcotuong Joined Aug 26, 2010 170 Jun 18, 2011 #23 Hi SgtWookie, It does work when I increase the cap of 220UF and up. Thanks, Kevin
M Thread Starter mpcotuong Joined Aug 26, 2010 170 Jun 19, 2011 #24 Hi SgtWookie and all, I have found out that if I turn on/off within 1 minute will trigger the motor run. Do you have any power switch delay 1 minute before the power turn on? Thanks, Kevin
