for this design of envelope detector ,
1- what's the function of D2.
2- why the output signal is inverted.
see attached pic.
see attached pic.
No, the negative peak is clamped to (one diode drop below) zero volts.The D2 is used as positive peak clamper and hence the out put appears as inverted that is with positive peak clamped to zero volt.
Yeah Ron I first thought the same that -ve peak is clamped coz of diode's polarity but eng_alaakaa's scope's output is not conforming to that. Could you plz. explain?No, the negative peak is clamped to (one diode drop below) zero volts.
The circuit is a voltage doubler (see Fig. 2).
