I think it's a super idea -- cheap, will likely work, and he can be up and experimenting in short order. The OP just has to be careful, as he will be working with dangerous voltages.So let's say you get four of these 4.2A 24v switching supplies, wire them in series, and use a 555 timer to drive a power MOSFET's gate for the pulsing.
He could get an extra one to use to drive a small audio speaker for mechanical positioning of the wires.
OK.beenthere said:Add the current limiter and possibly a reservoir capacitor. Makes an inexpensive experiment.
You might go the dual 555 route so you can vary duty cycle and frequency.
Thank you very much for the link on the DIY EDM!Here is a link to a do it your self pulse generator; http://www.rmcybernetics.com/projects/DIY_Devices/homemade_signal_generator2.htm
This is what I'm basing my EDM on. It will do anything that you need for what your trying to do.
Here are some photos of the mechanical parts of my machine. And a photo of a pulse form from one of the books I have on edm.
You do know that you don't have to use a pulse to erode the metal don't you? When the process was first discovered in the 1940's in Russia and up until the late 1960's they used a RC relaxation type circuit. It was only for more speed and to get around patents that they started using pulse.
This link; http://www.make-it-better.us/article.cfm?articleID=35
tells about the history and different types of machines.
I think I attached the article to this message.David, is there another address to the site you listed in your first post?
I've tried to go there several times a day and keep getting a cannot find message.
Is this, nano silver particles, another form of colloidal silver? If it is you should really read what they are saying about it's safety! Google "nano silver"
If it's not what is it used for? Sorry but I'm just curious.
Cary
Speaks volumes, doesn't it.I just received an email back from the guy whose email address is listed on the study.
He said he is too busy to help.
At some point, I'm just going to have to show my hand, so to speak, and I'm holding pretty much nothing. I hate to admit it, but I know very little about electronics or electrical circuits. What I do know is the end result I'm seeking. I'm also reasonably intelligent, able to follow instructions, worked in two machine shops for about 12 years, and several of those years I operated several wire EDM machines. And I did make and test an LED flashlight circuit successfully, if that counts for anything. I hope everyone doesn't run off and not help because they think I'm a hopeless case.David, I know the more experienced people told you to use a switcher/regulated supply but if it was me, I wouldn't.
Reread your description of what the circuit does/how it operates. Starts with a high open circuit voltage and voltage drops as the current rises. Again, just the exact same as Electrical DischargeMachining. In that type of circuit you just use a transformer/bridge diode/filter capacitor. No regulation.
It needs to "droop" like a arc welder transformer. Thats how you get the voltage drop as current rises.
Switcher supplies also don't like short circuits. And you will get short circuits doing this.
I don't know where your from but you really should invest in this book;
https://secure.villagepress.com/store/items/detail/item/797
before spending a lot of money on a machine to make your nano-silver. This machine has been built and tested.
Just my $.02 Because I've been where your at and spent a lot of money on building a EDM, before I had any real knowledge of what was needed.
Cary
